cs00bren Posted February 2, 2003 Share Posted February 2, 2003 hello they two questions the first i have a landscape surface and i want to cut a piece of the surface away in a boolean fashion. the second geometry is a surface. i've try using nurdes and using surfacesect and i've tryed making they polygons and extruding and then boolean but it dosn't seem to wrk any ideas. the second some one answered sells were: later save them as a sequence of geo (bgeo) files using Geometry ROP i understand what it does but i don't know where how to find and use this. cheers bren Quote Link to comment Share on other sites More sharing options...
danteA Posted February 2, 2003 Share Posted February 2, 2003 ROPs are in Outputs. Try using Cookie instead of Boolean on polygons. I just tried this with a vex mountain applied to a grid and then did an A minus B operation with the cookie of that grid with a poly tube and it seemed to work. I needed to do some clean up afterwards though with a blast sop. Quote Link to comment Share on other sites More sharing options...
