ivan Posted November 28, 2007 Share Posted November 28, 2007 is there a way to create a camera in python and then turn on it's roto tab? Quote Link to comment Share on other sites More sharing options...
crunch Posted November 28, 2007 Share Posted November 28, 2007 is there a way to create a camera in python and then turn on it's roto tab? I'm not 100% sure, but you might try obj = hou.node('/obj') cam = obj.createNode('cam') hou.hscript('opproperty %s viewport viewport_roto') might do the trick. I cheat though and use the hscript opproperty command. Quote Link to comment Share on other sites More sharing options...
ivan Posted November 28, 2007 Author Share Posted November 28, 2007 I'm not 100% sure, but you might try obj = hou.node('/obj') cam = obj.createNode('cam') hou.hscript('opproperty %s viewport viewport_roto') might do the trick. I cheat though and use the hscript opproperty command. error... what is %s? >>> hou.hscript('opproperty %s viewport viewport_roto') ('', 'No nodes match %s\n') error...what is %s? >>> hou.hscript('opproperty %s viewport viewport_roto') ('', 'No nodes match %s\n') >>> hou.hscript('opproperty /obj/cam1 viewport viewport_roto') works just fine.... thanks! Quote Link to comment Share on other sites More sharing options...
Jason Posted November 28, 2007 Share Posted November 28, 2007 error...what is %s? >>> hou.hscript('opproperty %s viewport viewport_roto') ('', 'No nodes match %s\n') >>> hou.hscript('opproperty /obj/cam1 viewport viewport_roto') works just fine.... thanks! He probably meant to finish the code properly like this: obj = hou.node('/obj') cam = obj.createNode('cam') hou.hscript('opproperty %s viewport viewport_roto'%cam.path()) Quote Link to comment Share on other sites More sharing options...
crunch Posted November 28, 2007 Share Posted November 28, 2007 hou.hscript('opproperty %s viewport viewport_roto'%cam.path())[/code] Yeah, what Jason said. Ooops. Quote Link to comment Share on other sites More sharing options...
Jason Posted November 28, 2007 Share Posted November 28, 2007 Yeah, what Jason said. Ooops. Its nice for me to fix some bugs for a change! Quote Link to comment Share on other sites More sharing options...
