Create chop channel from python data
N Senada
I've asked this on the sidefx forum but it went unanswered, so I thought I'd give it a try here.
In my noob imagination it should be really easy.
The title says it all really, I would like to create (or "write", "set", "import" into) a chop channel from python data (list, numpy array, dictionary or similar).
I just can't find any way to do this.
:wacko:
:wacko:
Hi,
you can save your data as ascii text file with extensions .clip or .chan, then read it with  File chop node.
Also you can bake you data to parameter on a sop node as keyframes and then fetch into CHOP with Fetch Parameters chop node, or save baked keyframes as a file with saveClip method of hou.Parm class.
  • Thanks 1
