lisux Posted December 13, 2007 Share Posted December 13, 2007 Hi odforce people. I am rendering some poligonal surfaces using the glass sahder suited with H9. When I set these poligons to be rendered as subds adding the corresponding rendering property to the object I get many errors messages like this: mantra: Repeated vertex found in polygon 177 (/obj/waterdrops1/water_drop) Where the poligon number is changing between messages, I et lot of thems from mantra. But If I render the poligons as is there is no problem. Even worse when I use subds and render a sequence I begin to receive the annoying messages and around frame 11 the render simply crash. So I have to disable render as subds. Somebody have had any experience with this? Thanks. Quote Link to comment Share on other sites More sharing options...
Jason Posted December 13, 2007 Share Posted December 13, 2007 Can you attach the geometry to this thread? We can take a look.. (Also, have you tried the latest 9.1 beta build?) Quote Link to comment Share on other sites More sharing options...
