cspears2002 Posted December 17, 2007 Share Posted December 17, 2007 ARGH! I'm using Houdini 9 Apprentice HD. I'm learning how to build a rollercoaster with an old tutorial. The colleague who gave it to me said it was written for Houdini 3-6. Anyway, I started with a polygonal box, which I extruded into the rough shape that I want for the rollercoaster's cars. Then I used the Polysplit SOP to split the car right down the middle. The tutorial calls for me to then select half of the car and blow it away with the Blast SOP. However, I can't seem to be able to select anything. I seem to be stuck in the Polysplit SOP even after I hit enter because I am still being prompted to pick edges to split. I tried just hitting the tab key and selecting the Blast SOP, but that just blows away the part of the car that was selected for the Polysplit SOP. What am I doing wrong? I attached the hipnc file of my scene. coaster_v02.hipnc Quote Link to comment Share on other sites More sharing options...
sibarrick Posted December 17, 2007 Share Posted December 17, 2007 In H9 you need to reverse the order of the instructions, select the geometry first and then tab select the operator. Hopefully that will sort you out. Quote Link to comment Share on other sites More sharing options...
kubabuk Posted December 17, 2007 Share Posted December 17, 2007 It was renamed to Delete (modify) in H9 but I use it only accidentally. I recommend Delete (attribute) - (old delete SOP which is much more flexible. kuba Quote Link to comment Share on other sites More sharing options...
digitallysane Posted December 17, 2007 Share Posted December 17, 2007 I recommend Delete (attribute) - (old delete SOP which is much more flexible. And much slower. If all you want to do is to blindly delete some polys or points while box-modelling, Blast SOP is the way to go, as it is much faster. Dragos Quote Link to comment Share on other sites More sharing options...
