What's the point of using OPENCL with CPU?
OPENCL is initially meant for GPU, right? But when the vram of the GPU can't handle the simulation, one can resort to the CPU by adding a line to the houdini environment file HOUDINI_OCL_DEVICETYPE=CPU
If I add that line, What is the point of checking opencl in the solver, if It's using CPU by default? is using OPENCL with CPU any different than simulating without OPENCL?
If you don't use the OpenCL branch, then it will run the C++ or VEX branch instead, and depending on the operation, that could be slower, especially if it's VEX. OpenCL on CPU in some cases can still be faster than even C++ depending on the data structures used or if they haven't fully vectorized the C++ code.
Edited by animatrix
