Renderman Output Properties Missing
Hey all,
We've just upgraded to Houdini 9 and having an issue with the Renderman Output Driver in Houdini. The attributues/properties seem to be missing from the H9 Renderman Output Driver in the Main and Properties tab but seem to be present in the H8 version.
Is this something to do with H9 or have i just done something completely wrong.
See Attachment...
Any help would be greatly appreciated! :)
Edited by chunkified
  • 2 weeks later...
I was not sure if I had understood you correctly so I kept in silence. All attributes I need are there in sub-tabs, can't you see them?
It seems also that Houdini builds this UI dynamically based on default rib renderer set in system. So if you modify HOUDINI_DEFAULT_RIB_RENDER to AIR for instance, Houdini will prepare this ROP for Air. Maybe this goes wrong in your case?
Anyway, my tabs look the same as yours and they work as expected.
cheers,
sy.
