How to align joints along a vector attribute
noc2
Hi;
I have a bunch of points that all have a vector attribute as in the ss below. I then turned these points into joints and want to align the generated joints' Y axis to their respective vector attributes. I used a rig attribute vop that runs on points and used a foreach transform vop node to loop over each joint. But the problem is that although I could bind the per point vector attribute into the loop, I just couldn't get the foreach transform to work on each point's respective vector attribute, it only works on the first point's vector attribute. This is so frustrating :(
How on earth can a such a simple task be done in a rig attrib vop?
Thankx in advance;
AJ
ALIGN_JOINTS_TO_VEC.hiplc
Edited by noc2
