Pointdist In Vops
Hello,
Is there an equivelent to the pointdist() function in VOPS? Im am extracting the uv coords from a piece of geo to about 100000 pts. It takes quite a long time to calculate using the pointdist() expression and am trying to find a way to make this run a bit more efficiently.
Thanks
hi SpencerL,
as far as I know there isn't such a func() in VEX nor VOP, but this may solve your problem:
http://forums.odforce.net/index.php?s=&amp...ost&p=41746
This is point cloud method in vex sop that finds the nearest point from pt. (see the second piece of code, first is a normal loop). Simply and very fast!
hope this help,
sy.
Edited by SYmek
