remlorestudios Posted September 18 Share Posted September 18 Hello! I need to shape the density (falloff on particular axis) on the ocean interior geometry. The Karma Volume (default) density is constant throughout the ocean interior obj. I tried converting the obj into a vdb to create a density attribute. Then I tried getting bbox min & max values manually using geopropvalue bboxmin, bboxmax & P > subtract > divide to get values and multiplied by the density. This doesn't seem to work as I get a half/half look most likely do to improper mapping... Could someone please rectify this and make it work? Thanks! oceaninteriorfalloff_karma.hipnc Quote Link to comment Share on other sites More sharing options...
paranoidx Posted September 20 Share Posted September 20 Try this in the shader. Here’s a MaterialX setup with XPU, just modify the P.y position Quote Link to comment Share on other sites More sharing options...
remlorestudios Posted September 20 Author Share Posted September 20 Yeah that works Thanks! Quote Link to comment Share on other sites More sharing options...
