sisqosnew Posted January 22, 2008 Share Posted January 22, 2008 (edited) There's a Light Template in H9. Somebody told me this node can link Prman Light shader, but it didn't work in rendering. (Q)How do I apply Prman Light shaders for Lights in H9? Thanks for your reading. Edited January 23, 2008 by sisqosnew Quote Link to comment Share on other sites More sharing options...
symek Posted January 22, 2008 Share Posted January 22, 2008 You don't have to use PRMan light shader with default lights at all. This will happen automagically. Also shadow setup is respected both for Mantra and PRMan. Unless you have good reason no need to use template. Just be sure to setup HOUDINI_DEFAULT_RIB_RENDERER for yours. hope this helps, sy. Quote Link to comment Share on other sites More sharing options...
sisqosnew Posted January 23, 2008 Author Share Posted January 23, 2008 (edited) I've checked what you said. Setuping HOUDINI_DEFAULT_RIB_RENDERER is for 3Delight. My renderer is Prman 12.5, but the common point light and spotlight can work directly without any shaders as you said. After test, Environment light can't work in Prman rendering. Do you find that? Edited January 24, 2008 by sisqosnew Quote Link to comment Share on other sites More sharing options...
symek Posted January 23, 2008 Share Posted January 23, 2008 Haven't tried this. But this is very probably that environmental light implemented in Houdini is special feature of mantra that hasn't straight equivalent i8 PRMan. Quote Link to comment Share on other sites More sharing options...
