Environment Setup Problem With H9.1.126 And Ubuntu 7.10 64bit
Cross-post with the mailing list, sorry for that.
Hi list,
During a process of moving my Houdini environment to Linux (x86_64), I'm also trying to setup the initial development environment so that I can compile some of the DSOs. I'm running a fairly vanilla Ubuntu 7.10 64bit on an Intel C2D with some development options added (as far as I can tell also all the 64bit gcc libs needed as well). I'm running the 9.1.126 daily build and it works just fine on the laptop.
Now, as a test I'm trying to compile some of the HDK samples and I get the following problem:
andrasikladi@NEPTUNEMBP:/skynet/houdini/91126/toolkit/samples/SOP$ hcustom SOP_Flatten.C
MACHTYPE: Undefined variable.
Making SOP_Flatten.o and /home/andrasikladi/houdini9.1/dso/SOP_Flatten.so from SOP_Flatten.C
SOP_Flatten.C:1: error: CPU you selected does not support x86-64 instruction set
Compile failed
I tried to set the $MACHTYPE variable to some meaningful values, to no avail.
When I dump (-e) the hcustom command script, it looks like this:
andrasikladi@NEPTUNEMBP:/skynet/houdini/91126/toolkit/samples/SOP$ hcustom -e SOP_Flatten.C
g++ -DUT_DSO_TAGINFO='"3262197cbf13471031a71e814c3690f8226efbd5ff16ec8a16dbbf681714bfd251bd2a8dcf7b25710746e2e67dda316b0eaaf57aae8cf95640162de16dfe90b64aa845b2ef8251bea3268d0847ba11fcab0c8ceacfa2986af7a45c0b1e01ad4dff578f"' -DVERSION=\" 9.1.126\" -DDLLEXPORT=  -D_GNU_SOURCE -DLINUX -DI386 -march=i686 -DSIZEOF_VOID_P=4 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -D_FILE_OFFSET_BITS=64 -c  -DGCC4 -DGCC3 -Wno-deprecated -I/skynet/houdini/91126/toolkit/include -I/skynet/houdini/91126/toolkit/include/htools -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-reorder -Wno-uninitialized -Wunused -Wno-unused-parameter -O2 -DMAKING_DSO -o SOP_Flatten.o SOP_Flatten.C
Compile failed
So it looks like it's using an I386 macro and an i686 CPU type. The docs say that hcustom should initialize my environment to the proper architecture (which I assume it does as all the library search paths..etc are setup properly).
I also tried to run HDKinstall (although it seems to have expanded everything already and the error message doesn't seem to complain about missing stuff):
root@NEPTUNEMBP:/skynet/houdini/91126# hdkinstall
Installing the HDK... done
NOTE: Building plug-ins for this installation of Houdini requires
g++ 3.x or higher.
??? What do you mean?
andrasikladi@NEPTUNEMBP:/skynet/houdini/91126# gcc -v
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.1.3 --program-suffix=-4.1 --enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug --enable-mpfr --enable-checking=release x86_64-linux-gnu
Thread model: posix
gcc version 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)
Looks like it has the right version of GCC.
I guess it must be something fairly basic I'm missing. Any clues/RTFMs (I've read the relevant chapters on the odForce wiki)?
Thanks,
Andras
