MetaBall particles
Mcronin
Pretty simple one. I have a surface I'm using as a source to generate particles. The particles are metaballs that are instanced through an instance POP. When I look at the viewer in POPs, I can clearly see the metaballs are fusing together, but when I render, they render as discrete, seperate metaballs. How can I get them to fuse in my final output?
  • 5 years later...
Hey guys. How do you get the metaballs to inherit the particle colors? I figured a Color SOP after the metaballs which would reference a stamped parameter in the Copy SOP, but it's not working for me. Any help would be appreciated :D
Guest Swann
Look on the last Tab in CopySOP and turn template point attributes. You don't need ColorSOP and stamp so throw it OUT. Color your particles in POP Network with ColorPOP. But it still won't help you with isosurface.
Check this, last post sounds interesting But I haven't succed with applying it.
Tip
Edited by SWANN
Guest Swann
just guessing.. you could pass your color thru with a attributetransfer SOP...
Oldschool ;) trick don't work in this case. You will get only one color.
Edited by SWANN
