rohandalvi Posted January 31, 2008 Share Posted January 31, 2008 Hi, Doesnt PBR support VOP VEX Surface Shop? I used the VOP VEX Surface Shop to create a simple material, it renders in the normal Micropolygon renderer, but it renders Black in PBR what is the reason, with regards Rohan dalvi Quote Link to comment Share on other sites More sharing options...
mark Posted January 31, 2008 Share Posted January 31, 2008 hi.. make sure you connect the BSDF from the lighting model node to the output node in the VOP network Quote Link to comment Share on other sites More sharing options...
rohandalvi Posted January 31, 2008 Author Share Posted January 31, 2008 thanks a lot , I never did that before, because it works without that in the Micropolygon renderer. So, Thanks once again. Quote Link to comment Share on other sites More sharing options...
