Kaito Ishikawa Posted 10 hours ago Share Posted 10 hours ago (edited) Hello! I have a question about the Pyro shader using Karma in Solaris. I want to use the Cd volume created in SOP for smoke color, but I don't know how. Redshift has a tutorial, but I want to use Karma CPU. https://youtu.be/KuI9B1MA6do?si=UbAWfRsf4ewwR__C I also want to use Cd volume for smoke color in karma, like in this tutorial. However, since I'm creating an explosion this time, I want to use scatter and control the flames as well. So my ideal setup would be to use the karma pyro shader as a base, set Cd volume to smoke color, and keep the scatter as-is. https://youtu.be/3RpTfeBdjKE?si=8sdL6z_-SfxJIwba As at the beginning of this tutorial, I created a CD volume. Please tell me if you know! Thank you, Kaito Ishikawa Edited 9 hours ago by Kaito Ishikawa Quote Link to comment Share on other sites More sharing options...
