jjstanley Posted February 13, 2008 Share Posted February 13, 2008 I was wondering if there is a way to adjust the range of a parameter in an OTL based on another parameter. I just want to make it so that one parameter can't be moved outside the range of another parameter to safe gaurd against conflicting parameters. I thought maybe opparm might work but I can only get it to affect the value not the range. Any ideas? Quote Link to comment Share on other sites More sharing options...
michael Posted February 13, 2008 Share Posted February 13, 2008 as far as I can tell you can't dynamically set the ranges of parameters in an HDA... what you can do is put an expression on the actual parameter you're controling...see clamp, fit etc Quote Link to comment Share on other sites More sharing options...
