Coz_y_not Posted January 1 Share Posted January 1 I have a geometry sequence that has substeps (saved as x number of substeps per frame). Would you have a standalone lops network graph or even a stand alone hip file just for that animated geometry with enable playback at fractional frames? or would you just mix it with other assets and simulations caches that are not saved with substeps? and if you mix it do you then enable playback at fractional frames? and if you do enable the fractional frames would that impact the other non substep elements during rendering? Quote Link to comment Share on other sites More sharing options...
tamagochy Posted Monday at 05:31 PM Share Posted Monday at 05:31 PM First youy need to understand why you need substeps. In 99.9% of cases you dont, and if you save caches with substeps you can use usual timeline. Houdini get access to subframes in simulations or when you retime youe caches. Quote Link to comment Share on other sites More sharing options...
