attribute and variables
hello.
i'm trying to understand how attributes and variables works.
i read this http://www.sidefx.com/index.php?option=com...ighlight=#52982
and now i have sonme question.
if variables "are merely a shorthand way to look up a particular attributes value" i could use only attributes,using point() expression, and no variables?
if i look in the help of point SOP, i see there are many local variables. so, each of these has a corrispective attribute?
if so, that about the $PT varialbe?
i'm a little confused... :unsure:
No. Quote from above thread:
Both local variables and attributes can refer to the same data (...). But they don't have to.
There are a number of variables that don't have a corresponding attributes. $OS, $BB[XYZ], $CE[XYZ]. These are automata to compute for you useful information but they are not directly related to any attribute on geometry (besides centroid is related to geometry position of course ;) ).
Edited by SYmek
:D thanks a lot!
what is $OS variable?
if i want to know what is a variable, is there a way to search it in the help? i haven't found anything about $OS :unsure:
:D thanks a lot!
Its the name of the current node in which the parameter is evaluated. It's the same as `opname(".")`
$OS is a name of the operator executes variable:
http://www.sidefx.com/docs/houdini9.1/expressions/_globals
or if you don't mind read in Polish ;):
http://www.forum3d.pl/f3dbb/index.php?md=p...d=122878#122878
$OS is global and $BB[XYZ] are locals of course but they both don't have attributes equivalents.
Edited by SYmek
it's a global variable! i missed that! :P thankyou.
if i search in the help for each operator, i should find a list of all available locals variables, right?
if i look fot the group SOP, there is nothing, but i know can use $CR for example. why it's not listed?
maybe, if in the help are not listed local variables i can use standard local variables? :blink:
