Move point group to position vector
Rine-Hart
I keep banging my head against a wall with this and know the solution may be super simple.
I have a vellum wire sim where the wires snap to pts on columns. I would like to have a certain number of points at the end of the wires align to the normal of the point to which they are snapping, instead of dangling at weird angles.
I would love to get this running in the solver to keep the overall wire sim looking smooth. My brain keeps farting over the vector math and now I must rest.
Any direction/assistance is always greatly appreciated. Also understand if this solution can be found on another topic
Think how it works in the real world. If you need to align ends with the columns, maybe it must be so initially before doing wire sim?
Thank you so much!
Fortunately, Houdini is not the real world, it's vector math magic.
What I would like is to understand is the linear algebra behind moving a group of simulated points to align to a directional vector.
I apologize if that wasn't clear from the above. Any assistance with the math involved in this would be greatly appreciated.
Holy Cannolli!! This is a brilliantly elegant real world solution! Much better that the 'fix it in post' hack job I was thinking.
This gives me a tremendous amount to work with. Let me try and implement some of this and I may return with more questions.
Thank you so very much for taking the time to build this out. Greatly appreciated!
Thank you again for this reference. Wondering how I might get this alignment from both ends?
I've tried a few things within the for loop, like lerping between 2 different P's, but have kind of hit a wall.
Again, very greatly appreciated.
@fencer You are too kind sir!! Thank you again.
I was correct in my reasoning by creating a separate align off of the root normal. but was over complicating everything in the mix.
Thank you for sharing your knowledge, this is wildly helpful!!
