nemsi Posted May 13 Share Posted May 13 After years working in 3D for advertising and cosmetics, I kept running into the same bottleneck: label creation and integration. Time-consuming, repetitive, and rarely optimized for production workflows. So I built a solution. Easy Label Forge is designed for 3D artists who need speed, precision, and flexibility when working on packaging and product visuals. What it does: Automates label creation and placement Automates shader setup across multiple 3D applications Keeps everything clean, consistent, and production-ready Save hours on every project Focus on creativity instead of repetitive setup Works seamlessly across pipelines (Blender, Houdini, Cinema 4D, Unreal Engine…) Whether you're in cosmetics, advertising, or product design, this tool is built to fit into real-world workflows and remove friction where it hurts most. I created Easy Label Forge to solve a problem I personally faced for years, now it’s ready to help other artists do the same. A trial is avalaible. https://easylabelforge.com/Setup_EasyLabelForge_v2.5.0.exe https://easylabelforge.com/ hashtag#3D hashtag#CGI hashtag#Houdini hashtag#Blender hashtag#Cinema4D hashtag#UnrealEngine Quote Link to comment Share on other sites More sharing options...
nemsi Posted May 25 Author Share Posted May 25 Release Notes: LabelForge V2.7.3 Peak Performance and better compatibility Universal PDF & Adobe Illustrator (.ai) Ingestion The integration of a new, ultra-robust "brute-force" analysis engine guarantees more successfully conversion of PDF or Illustrator (.ai) file into a native LabelForge session. Even if your print files contain complex clipping paths, nested masks, or non-standard vector structures, LabelForge decodes them flawlessly so you can start working instantly. Advanced UV Projection (Frustum Engine) Master conical shapes: The highly anticipated integration of Frustum projection technology unlocks flawless UV wrapping on conical or flared objects (cups, cosmetics jars, tapered bottles). LabelForge now wraps these complex geometries with absolute mathematical precision. Fast Workflow in the Mask Designer Production hotkeys: The interface gets essential keyboard shortcuts to speed up organization. Press Ctrl + G to instantly create a new mask group, or Shift + Ctrl + G to quickly add your selected layers to an existing group. Full Support for Emissive Textures Make your designs glow: The "Use Label Artwork" option is now fully supported on the Emission channel. You can directly drive the glowing parts of your packagings (screens, LEDs, phosphorescent inks) using your graphics layers with a single click in Shader Studio. Universal and Automatic Integration in Your Render Engines 3D export has been optimized to automatically set up your emissive shader networks in all major platforms: Blender, Houdini, Cinema 4D Enhanced Export Safety and Stability The .json recipe export pipeline has been consolidated. Even your most complex material structures are guaranteed to transfer intact to your 3D application, providing 100% reliability for studio production. Download: https://easylabelforge.com/download.html Quote Link to comment Share on other sites More sharing options...
