How To Randomize Instances For Particles
wreath
Hı i need a setup like; same source emitting particles with different instanced objects ( box,sphere etc.) i tried copy op with switching different objects but it's not working for this when primitive objects changed whole particles (already emitted ones) changing. Now i'm trying instance pop, instanced 1 geometry which have 3 different grouped objects but i can't figure out how to solve so need your help.
cheers
DP.hipnc
Edited by wreath
Hey
Firstly your objects that you are going to instance should be at the scene origin, orientated down the Z axis.
What you doing with the instance POP is copying the whole GEO onto each point, which i dont think you want to do.
So to fix this,
Center all your objects ie sphere, box, teapot etc
then in SOP's, append a copy sop and swap the merge out with a switch node.
I combined all your objects into one geo node, just because its simpler, but you can use an object merge to bring your pop net into ur instances GEO.
Then i used stamping with the point ID to achieve instancing a different object onto each point.
Take a look at the file, and hopefully its what you are looking for :)
DP_fixed.hipnc
cheers
