456.cmd or.py
does it work for somebody?
i read it in the houdini on the spot book, but it does not work. it should be executed when after File>New , but I get a empty default scene
I use all the time and it works. What is your path for that file? Also, if there is an error in a code, maybe Houdini refuses to execute it without warnings? Are you sure the code is ok?
it works as expected when i call it 123.py, and it lies in my $home/houdini9.1/scripts/
its quite simple right now:
hou.node("/obj").createNode("geo", "default")
mantra = hou.node("/out").createNode("ifd", "default")
Edited by sanostol
maybe importing hou will help? Did you import it?
Edited by SYmek
allready tried that, no success
Hey Martin,
what build and OS you're using? I checked on Linux (9.1.189) yesterday evening and also couldn't get these scripts to work, but I'm not sure if all paths are set correctly there. This is strange. If I recall right, 456.py won't work in there is no 123.py file (am I right?) but this is the only warnings about it I can tell. A few weeks ago when I was writing some info about these files here: http://www.forum3d.pl/f3dbb/index.php?md=p...d=122885#122885, I was testing everything on Windows, files were present in all paths ($HFS, $HSITE, $HOME, $JOB) and Houdini was dealing with them correctly. hmm...
Edited by SYmek
thanks SYmek for Your effort,
my os is ubuntu 7.10 the houdini version is 9.1.197
i have a empty 123.py and a 456.py, on the startup the 456 is executed, but not with new file
on windows i get a error( don't know the build right now)
i will try a new build
Hey Martin,
Edited by sanostol
