geometry OUt
for $i = 1 to 10 step 1
fcur $i
opsave /obj/my_model/my_sop C:/temp/dmp.$F.bgeo
end
"help opsave" says that you can do something like
  Quote
opsave [-v] [-f start end] [-i inc] operator filename
opsave -f 1 10 -i 2 twist1\$F.bgeo twist1
But the above example will just save 10 different bgeo files over top of [the current value of $F].bgeo. So this is why I used the for loop. I have no idea how to use opsave to output a different file in a sequence by using the -f option. :unsure: Any ideas?
And on another note.... the pdf help gives this example
opsave -f 1 10 -i 2 twist1 twist1\$F.rib
while the "help opsave" gives this
opsave -f 1 10 -i 2 twist1\$F.rib twist1
The correct form is opsave OBJECT FILENAME (as stated in the pdf)
jim.
