particle avoidance on self-generated geometry
pencha
Look into using an Interact POP to prevent the particles from intersecting each other. I posted an example in this thread.
Cheers!
steven
Thanks for the fast reply!!!
I have been trying with interact pop yesterday but what I got is that the top of each tentacle only reacts to the TOP of other tentacle, and not to the trails (or actual tentacles). What I need is that every top of every tentacle doesn
After splitting the particles, they are a seperate particle system so you have to connect an Interact POP after the Split POP. This should help with the particles that make up the body.
Unfortunately, there isn't a way to have the control you want.
Cheers!
steven
Cheers!
steven
Thanks again Steven!!
The interact was on his place but as they are stopped the "live" ones don
