need help for iceberg
This would look great with sss, rather then a refractive/reflective material.
probably a bit of fresnel combined with a ligthing model to get more snowy edges where the object is lit -increases rimm light effect/light wrapping effect a bit.
- you might consider making this a suggestion in rdg "one shader a day thread" I am sure this kind of material will benefit more people and would provide a nice little challenge.
Edited by pclaes
I think Pclaes has made a nice suggestion there.
Try the AXIS_OTL shader in the SSS Diaries thread I think it is on 13 page or you can get it from Exchange also.
Take a separate SSS pass and comp it with ur Ambient Occlusion pass and play around with colour will give u some good results.Also you displacement should be effective and convince on top of everything.
HTH.
HTH.
