raytrace in sop/vop
i just discovered the intersectVOP, but it askes for a file for the target geometry. there are some nodes that ask for a file. but I don.t understand why I cant't plug in a normal geometry from the scene. these from filestuff is very confusing to me. whats all about it?
when it asks for a bgeo file, instead of using the file you can use the syntax
op:/obj/geo1/mypts_SOP
instead of writing out a file. Just make sure you use a full path after the "op:" and not a relative path but you can get around this by using the opfullpath() expression.
thanks a lot Spencer, You helped me out again :)
so many backdoors, someone has to write the another book about it.
