kubabuk Posted May 12, 2008 Share Posted May 12, 2008 Hello all, I am trying to replace functionality of some hscripts commands used in my ROP, like strcat, strreplace, substr etc. with python expressions. Basically what I am up to is to source the path, get rid of the extension, create a directory and save a file with a different extension in that directory. I have a python script which works fine up to the creation of the folder in the houdini python shell. So I thought the only thing I need to do is to past the script into the one of the filed of the ROP to have the job done. BUT it isn't so simple. I am definetly missing something here that's why I have some question to you guys. I haven't found much about python expressions in the help, so please help! Is it something different to Python I use in python shell? Does python expressions have some limitations are they restricted to one line or so? Have they been implemented yet? Do I have to brace python scripts from python shell with backticks the same it is with hscript and expressions to use them properly? As you can see I haven't had luck with them yet. thanks for help kuba Quote Link to comment Share on other sites More sharing options...
graham Posted May 12, 2008 Share Posted May 12, 2008 (edited) Python expressions are not limited to one line. To do more than a single expression you have to make sure to return a value to a parameter that is expecting one. For example, the ty of a geo node can be set using a sin wave from python's math library. import math return math.sin(math.radians(frame())) The python in a parameter only differs from that in the shell in that it automatically does a 'from hou import *' for you. Also, any modules that you import in the shell are not imported in parameters so you have to import any modules in the parameter code. No sort of bracing or anything is needed. There really are no 'Python Expressions'. Python is python. It's not like the Hscript / Hscript Expressions. No sort of bracing is needed. Edited May 12, 2008 by graham Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 13, 2008 Author Share Posted May 13, 2008 Thanks, it is pretty straightforward once one knows how it works. Love it! This goes into the rop_geometry file field, for anyone who wants to push it further: import os,hou # store the path to the loaded jpg fullpath = hou.evalParm('../trace6/file') path = fullpath.split(".") print path # declare new extension obj = ".obj" # declare folder name to store new files in folder = "geo2" print path[0] corepath = path[0].split("/") # store the name of the jpg file file_name = corepath.pop(-1) print file_name # remove the last element - the file name from the list del corepath[-1] print corepath print file_name new_core_path = '/'.join(corepath) print new_core_path # set the new path to the folder new_file_path = new_core_path+'/'+folder print new_file_path if os.path.exists(new_file_path): print 'warning - folder already exists' else: os.mkdir(new_file_path) # set the final path fot the obj file final_path = new_file_path+'/'+ file_name + obj print final_path return final_path have a nice day kuba Quote Link to comment Share on other sites More sharing options...
old school Posted May 13, 2008 Share Posted May 13, 2008 Nice simple example showing how straightforward python can be. Thank-you. Quote Link to comment Share on other sites More sharing options...
