objects disappeared in fluids simulation
Hi everyone,
I'm trying to run a dynamic simulation with fluids and RBD objects. But some RBD objects just disappeared after a certain frame (frame 86 in my case).The scene is pretty simple, just water flash hitting some objects, and the objects stay at the bottom of the water.
when I checked the detailed view of the RBD objects after it disappeared, I found that some parameters became [nan, nan, nan]. these parameters include angvel, t, vel.
what does that mean? how could I fix it? If anyone could give me some hint, that would help me a lot.
Thanks.
hi curveU,
Maybe if you increase the resolution of the fluid and/or the rbd objects (volume represetation) will fix the problem. it looks like inter penetration problem to me. also the solver substeps might help here too.
Hope this helps
Cheers
