Particles generated from RBD Impacts
Farid
The problem is in the expression for the object name you are attempting to reference in the Copy and Point Sops.
frag_* + stamp() isn't what you want since your object names are frag##_
"frag" + padzero(2,stamp("..","FORVALUE",0)) + "_" will work correctly.
The padzero is necessary since your group names are 00, 01, ... 20 and the stamp value is 0, 1, ... 20.
Edited by graham
The problem is that all your expressions are wrong syntax wise.
In the Copy sop you have:
dopnumrecords("/obj/AutoDopNetwork","frag" + padzero(2, stamp("..","FORVALUE",0),"Impacts","Impacts"))+"_"
The '+"_" is in the wrong place. It should be
dopnumrecords("/obj/AutoDopNetwork", "frag" + padzero(2, stamp("..","FORVALUE",0)) + "_", "Impacts" ,"Impacts")
The same little problem occurs in the Point Sop expression as well.
Attached is a working version.
working.hipFetching info...
Edited by graham
Thanks Graham ,
Its working perfect.
why are u using 10 * npoints(opinputpath("../",0))??
I will be using this system for my fallen object so as they fall they should emit sprites so that i can apply dust shader onto them .It will definitely be a lot of help.
Thanks alot for helping me out here.
zasid
