lisux Posted May 23, 2008 Share Posted May 23, 2008 Hi houdiniks I am experimenting some issues with the paint capture weight tool. The thing is that in H9 it seems to not work properly, moreover when you want to previz your model at the same time is deformed, the tool puts the paint capture node before the deform node and set the display flag to this last one so you can Quote Link to comment Share on other sites More sharing options...
edward Posted May 25, 2008 Share Posted May 25, 2008 If you enter the tool in the viewport (ie. have the paint node selected and hit Enter in the viewer), then you should be able to paint on the deforming geometry directly. Make sure you're using Show Current Operator though. Quote Link to comment Share on other sites More sharing options...
