Strange flickering problem
Hello Guys,
I have been cracking my head to solve this problem.I am still getting it all the time .
This problem appears rite after I apply displacement even it if it as low as -0.009
I used high pixel sampling in mantra from default 3 to 12 but it is still appearing.
I also make sure that the camera far clipping is beyond the object and it should be inside the camera clipping planes
I also used some pixel filtering but it keeps on appearing .
Its 4 am and the problem is unsolved :) please help guys thanks
take a look at my video file.
Please note that each object which is fractured object is using 3 different textures at 3 different levels TOP MIDDLE and BOTTOM.
Many Thanks .
Awaiting response anxiously.
zasid
flicker.mov
Hello guys,
Never mind I think I have solved the problem the problem was because of the rat file format. I was using jpeg instead of rats and I think it has solved the problem.
Many thanks for all your never ending support and help.
regards,
zasid.
