melany Posted May 27, 2008 Share Posted May 27, 2008 helloooooo! I have a model of a fish and a displacement map. I need to embed the displacement map into the smooth model so that all the details of the bump map becomes geometry. Does anyone know how to do this? All suggestions are very much appreciated! Thanks Quote Link to comment Share on other sites More sharing options...
old school Posted May 27, 2008 Share Posted May 27, 2008 I attached a SOP Digital Asset that allows you to displace geometry using an image. It has some nice convenience options as well. You can install the digital asset using the File > Install Digital Asset Library and bring in the .otl file. The tool in SOPs is called "Displace By Map" and should fall in the "Digital Assets" tab operator menu. This is just a wrapper on top of a vop network which is doing the actual displacement. displace_by_map.otl 3 Quote Link to comment Share on other sites More sharing options...
melany Posted May 27, 2008 Author Share Posted May 27, 2008 I attached a SOP Digital Asset that allows you to displace geometry using an image. It has some nice convenience options as well.You can install the digital asset using the File > Install Digital Asset Library and bring in the .otl file. The tool in SOPs is called "Displace By Map" and should fall in the "Digital Assets" tab operator menu. This is just a wrapper on top of a vop network which is doing the actual displacement. Hey oldschool! thank u very much! I will try it straight away! Mel XX Quote Link to comment Share on other sites More sharing options...
kumpa Posted May 27, 2008 Share Posted May 27, 2008 (edited) you need to create VOP SOP using displace along normal node. Edited May 27, 2008 by kumpa Quote Link to comment Share on other sites More sharing options...
old school Posted May 28, 2008 Share Posted May 28, 2008 Exactly kumpa. I have that same network but with the ability to have the map black up, white down or grey centered displacements. I do that all the time now with my displacement maps. I added some extra convenience features, group functionality and the ability to add uv's in case they aren't present. Quote Link to comment Share on other sites More sharing options...
kumpa Posted May 28, 2008 Share Posted May 28, 2008 sry for redundant post, looks like i forgot to refresh page prior to writing post Quote Link to comment Share on other sites More sharing options...
old school Posted May 29, 2008 Share Posted May 29, 2008 Your post was perfect and clearly shows how to do this from scratch in VOPs! Here's an updated version of the asset above. I added the option to supply your own uv attribute (easily seen from your vop net no less!) plus a lot of clean-up. displace_by_map.otl 1 Quote Link to comment Share on other sites More sharing options...
felinearts Posted January 26, 2018 Share Posted January 26, 2018 this post is old but made me learn something new!! thank you old school!! Quote Link to comment Share on other sites More sharing options...
