Symbolic Posted June 9, 2008 Share Posted June 9, 2008 Hi, I am posting a file... In this file I have created a simple system that uses CHOPs to create variations in animation through one single slider... Thanks to the "OdForce" and "Side Effects" forums... and everybody who has contributed to the topic. Now I have two problems: 1) There are lots of channels... But what I need is... I need a noise in those channels (I have it now!)... but the next value on the channel should always be bigger than the previous one... Which means that the speed of growth should vary.. but the growth should never go backwards. That's why now... my animation goes forward and backwards... i could not get a growth that goes always in the positive direction. Which is weird... I did everything to constrain the noise between positive values... and then I add those positive values to my initial animation channel... and I still get valleys in my graphs... !? 2) The second problems is that I would like to have the first value for each channel at "0" (I have it now!) and the last value at "1"... and of course have a proper noise in between... I could not do that as well. Please help. Cheers. grow_var_v1r6_forPost.hip Quote Link to comment Share on other sites More sharing options...
cheebachops Posted June 10, 2008 Share Posted June 10, 2008 I Know little about chops so may be way off, but can you use an expression to link the 0 value to frame 1 and the 1 for last frame with the other frame values adding to values inbetween? Sorry if that isn't too clear it's very late at night. Quote Link to comment Share on other sites More sharing options...
Symbolic Posted June 10, 2008 Author Share Posted June 10, 2008 hello cheebachops, Thanks... But I do not have much to do with Frame numbers... What I am trying to achieve is... have all channels starting at "0"... then climbing up to "1" through a noise... and then meet at "1"... Sorry if I am not able to understand your solution... Cheers. Quote Link to comment Share on other sites More sharing options...
edward Posted June 10, 2008 Share Posted June 10, 2008 Try experimenting with the Area CHOP. Quote Link to comment Share on other sites More sharing options...
Symbolic Posted June 10, 2008 Author Share Posted June 10, 2008 Try experimenting with the Area CHOP. ...hello... I had a look but... no useful results. ...to be honest i am not that good in CHOPs and the Area CHOP really looks scary... Quote Link to comment Share on other sites More sharing options...
andrewlowell Posted June 11, 2008 Share Posted June 11, 2008 Must sssleeeep .. must resist answering CHOPs question ok fine here ya go ...hello... I had a look but... no useful results. ...to be honest i am not that good in CHOPs and the Area CHOP really looks scary... alowellspeepychops.hip Quote Link to comment Share on other sites More sharing options...
Symbolic Posted June 11, 2008 Author Share Posted June 11, 2008 Must sssleeeep .. must resist answering CHOPs questionok fine here ya go Yeah! Thank you very much Andrew... Works great! Cheers. P.S: It is hard to resist a charming CHOPs question Quote Link to comment Share on other sites More sharing options...
