Preserve Group/attribute help
jason_slab
hey
i've got an attribute coming in from a SOP solver that i want to use as a trigger to put my RBD's into a Group, i also need this group to be preserved.
i've been looking at this for a while and can't seem to come up with any solutions :angry:
any ideas?
thx
jason
Assuming you have a point per rbd object, and that you can figure out some sort of relationship between the objects and the points using $OBJ or $OBJID, you can just use a point expression in the Group Expression field... something like: point("../sopnet",$OBJID,"triggerattribute",0).
Now just ensure that in your sopsolver the trigger attribute remains on once set, so that the group persists.
-z
Edited by anakin78z
hey thx
i got my groups working, using this expression:
point("/obj/DopNet:$OBJID/Geometry",$OBJID,"freeze",0)
i'm still however having trouble getting my group to be preserved when my attribute goes back to 0
attached is a simple setup using a color as a attribute
jason
rbd_rnd_group_by_color.hip
hey thx
jason
The trick is to only update the points if they're not already at 1 :). Put a group sop before the attribtransfer and group all points which at at 0 (or below whatever threshold you like), then use that group in the attribtransfer sop. This way, any points that are already above that threshold won't pick up new color, and won't go back to 0. Make sure you delete the group again before the OUT sop, as it'll otherwise complain that the group already exists.
Also, make sure you don't delete the color attribute.
-z
Hey Jason,
Check out the DelayedSmokeHandoff example & look at the Data set up. One DOP to check out is the Modify Data DOP where you can use Boolean Type to set the value to 1 and you create your group based on that so you get a "Preserve Group" setup.
Hope the above helps!
Cheers!
steven
