thinkinmonkey Posted June 20, 2008 Share Posted June 20, 2008 Hi all, I'm a new Houdini user and I'm discovering the power of this application dreaming a day to work with ! So I've studying some tutorials taken by sidefx. Now I have problem and I don't know how to solve. I have a simple grid that I want to displace with a VOPSOP operator driven by an image, what I need is to displace phisically points, so not in rendertime, because I need to know their positions for a next step in my little project. I've created a UVTexture to set UV and a simple material. Then I've created the VOPSOP node using a tutorial about creating elevation map, but my node doesn't work: i think it's about uv, but I'm not sure. I've attached my working file so I hope it could be usefull for everyone who wants to help me. Thanks in advance. Michael elevation.zip Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted June 20, 2008 Share Posted June 20, 2008 change the uv from caps to lower case i.e. UV to uv in your parameter vop reading in UV. Quote Link to comment Share on other sites More sharing options...
thinkinmonkey Posted June 20, 2008 Author Share Posted June 20, 2008 GallenWolf, REALLY THANKS !!! It works ! I'm not sure why the uppercase was the problem, I could think Houdini will automatically find a vector node with "uv" as parameter name to take uv from the mesh: god, one day I have to read the manual instead to start with projects ! Thanks again. Michael Quote Link to comment Share on other sites More sharing options...
