point cloud presentation doesn't work in H 9.1
MENOZ
the point cloud presentation doesn't work on houdini 9.1
http://www.sidefx.com/index.php?option=com...&Itemid=137
and my old houdini 8.1 can't get a licence from sidefx.
how can i do? is there a way to see the files in houdini 9.1 ?
thank you!
Could you be more specific about which example doesn't work? There could be minor changes in a way Houdini works with vex code/shaders or so, but in general all should be fine. Any details?
cheers,
sy.
Edited by SYmek
Could you be more specific about which example doesn't work? There could be minor changes in a way Houdini workd with vex code/shaders or so, but in general all should works fine. Any details?
cheers,
sy.
pcBulletHoles craashes houdini
pcCloud seems to work
pcComp when i open i have warning message:
skipping unrecognized parameter "filter"
skipping unrecognized parameter "width"
skipping unrecognized parameter "extrapol"
skipping unrecognized parameter "interp"
pcOcclusion crashes houdini
pcWake crashes houdini too
these are names of folders in wich i found the hip files
can you help me?
thank you!
Yeah, it's been a while since I put this presentation together. Unfortunately I'm kind of busy at the moment, but if I can find
the time I'll see if I can re-work some of these hip files
I've just checked it. Except pcWave which seems to have a problem with spline VOP, all is fine. Warnings on startup are ok. They appear in most old scenes but aren't problematic.
