mawi Posted June 25, 2008 Share Posted June 25, 2008 Hi. I Quote Link to comment Share on other sites More sharing options...
symek Posted June 26, 2008 Share Posted June 26, 2008 (edited) Hi, in Houdini, similar to Maya as I thought, you can think about two or even three languages: 1. Languages: - Hscript (look for help in Texport via "help") - Expressions (look for help in Texport via "exhelp") - Python -(gosh, lets add the forth: VEX) 2. Differences in use: - Hscript executes commands (add operator, delete, rename, link) - expressions computes a value (compute angle, matrix etx) - (Python does both) - (VEX modifies variable's value like point position, surface colour, pixel value etc) 3. Backticks usage: - backticks allows you to place expressions in hscript... - or execute expression in a parameter that does NOT expect numeric value (like string parameter) for example, in file input path, you could write: op:/`opinputpath(".",0)` or: ./my_great_texture.`padzero($F-10)`.rat since this input file field expect string and it couldn't recognize padzero() as an expression in other way. But in case of translation parameter you need just an expression: fit01(rand($PT), 0.5, 1)) without backticks, since a parameter expects numeric value anyway. So: - using expressions inside hscript requires `` - you also need `` to evaluate an expression in non-numeric neighborhood, like strings, paths etc. - but you don't need it if expression is evaluated in numeric parameter. - you can also in opposite use hscript in expression with "run()" or "execute()" functions. - both expressions and hscript are accessible in Python with hou.hscript() or hou.hscriptExpression() (Unless they have pure equivalents in Python like opadd == hou.createNode() ). hope this helps, Simon. PS There are also expressions returning strings like points(), chs() and they need backticks also to be executed in parameters but not taken "as is". Edited June 26, 2008 by SYmek 3 Quote Link to comment Share on other sites More sharing options...
mawi Posted June 26, 2008 Author Share Posted June 26, 2008 Just perfect SYmek, I got it. Thanks. Martin. Quote Link to comment Share on other sites More sharing options...
symek Posted June 26, 2008 Share Posted June 26, 2008 Just perfect SYmek, I got it.Thanks. Martin. Glad to hear that although I hope I didn't confuse anything here. Houdini is rather broad topic... Quote Link to comment Share on other sites More sharing options...
