why cant I render? FX Tools:Heavy Smoke.
cloudfx
Hi all,
I downloaded shelf : FX Tools,
and place "heavy smoke" into a new scene,
I set up new camera, light, and mantra node.
But when I rendered, it returns only blank black image.
I can see all the sphere and emitters in viewport..
Thanks,
-J
Hello Jae,
Just click ur heavy smoke otl and go into the parameters window .
if u scroll down there is button create shadow lite press that .
and then try to render hope fully it will solve the problem cheers!
Hello Jae...
Make sure you press "Save Metaball Frame" or ("Save Metaball Sequence" if you are rendering a sequence) before you do the render. It needs to write the volume to disk before you do the render.
I hope it helps.
That was it.
I should've 'Save Metaball Frame' before I render. now I got it.
Thanks a lot!
:lol:
