getting into rigging - help highly appreciated
i am having a problem here
when i move the rig it has acceptable performance - not great but acceptable
but then when i put a keyframe on it - it becomes a lot slower
when i put a second keyframe on another frame - it becomes even slower
after the third keyframe on a third frame - the rig becomes unusably slow
its always writes out cooking this and that node in the lower left corner
i am just putting keyframes onto the root controller TX TY TZ
what can that be ?
oldschool mentioned that there is a problem when you put keyframes onto chops because every keyframe increases the load on the chops
is that whats happening in my rig ?
i am just using chops for distance calculation nothing fancy
keyframe_cooking2.mov
Edited by KrisStaber
yeah it looks like chops is the problem because it's trying to calculate the entire range. Here are three different things you could do to speed it up:
1. the object? chop has a parameter called channel range, change that to "use current frame"
2. use the distance() expression in parameters instead of chops to calculate the distance, that will just calculate for the current frame
3. object merge the point1 inside the nulls in another geometry object, and use a vop sop to calculate the distance: Subtract the position of one point from another, then pipe that into a length vop, which will give you the distance, which you can write to an attribute, then call that attribute value from anywhere else by using the point() expression. It sounds like more steps but this way might actually be quite fast.
what can that be ?
oh chops are definitely usable in a rig, as long as you limit their calculation so they don't try to calculate the entire timeline every time you move the rig
if you need that functionality for some secondary animation however, then you can make a switch to turn it off while keyframing the base animation, then turn it on to see the result with the secondary animation.
You can also check the performance monitor, it can give you realtime output of the time it takes each node to process... so these types of situations are easier to troubleshoot; you can see exactly which node is the bottleneck.
thanks a lot josh
i will give them a try
would be a bummer if chops would not be usable in rigs - they are awesome
do autorigs use chops ?
in the mean time i adapted the rig to another character
same rig different character
just reporting that this fixed the issue with the cooking
setting keys does not start a 5 minutes cooking process now
just took me a while to change that
i must have like 40 to 50 distance checks via chops in my rig
oldschool strongly advised me against using chops for something like that
but i cant really get the right distance via the distance expression
keyframing_.mov
great work Kris!
good luck with your presentation!
thanks michael
there is a lot to change or make better in that rig
technically and usability wise - its a bit "hacky" at the moment
the functionality is in there but not implemented ideally
but i guess for ~5 weeks without any prior houdini knowledge thats ok
it was more of a "lets see if I can rig in houdini"
I may start from scratch - redo the whole thing and make it really clean and consistant
then i could give it to the community to use
  • 2 months later...
I just skimmed through my thread and realized that i didnt write it anywhere
i think houdini is by far the best tool for rigging i have seen so far (xsi, maya, 3dsm)
at least telling from how far i got with it
unfortunately i was not able to see how rigging/animation in houdini works in a production environment
Which is something i would love to do since i think houdini is an amazaing package !
for production I mostly use maya (due to the people and companies I work with)
things that are a pain in other packages are supersimple to implement in houdini
some things could use an update or attention from the developers to make it more streamlined
and even more userfriendly
but every software has that problem i guess
unfortunately it does not look like i will have time to redo the rig anytime soon
or create tutorials (hope that new buzz thing is useful - would have been great to have that when i started)
i am now back in vienna animating for games and commercials
here are the videos and the documentation
adapting the rig: http://krisstaber.at/posted/krigger/krigger_adapt_HD.mov
quick walkthrough of the rig: http://krisstaber.at/posted/krigger/krigge...kthrough_HD.mov
documentation: http://krisstaber.at/posted/krigger/frameset.htm
