cloudfx Posted July 22, 2008 Share Posted July 22, 2008 (edited) Hi all, I made a sub-network, inside of it, I made a geometry sop node and I wired sub-network input 1 to input of the geometry sop node. PICTURE1 inside of the geometry sop node, I want to create the input node. which is like picture 1 PICTURE2 How do I do it? I was looking for that in TAB menu.. but it seems like its not there.. Thanks! -J Edited July 22, 2008 by Jae Yoo Quote Link to comment Share on other sites More sharing options...
michael Posted July 22, 2008 Share Posted July 22, 2008 it's not needed... in the top picture you're passing transform info to the 'part_creep' node NOT geometry in the second picture you're creating geometry with the sphere1 node... if you want to bring in geometry use the object_merge node. Quote Link to comment Share on other sites More sharing options...
cloudfx Posted July 22, 2008 Author Share Posted July 22, 2008 it's not needed...in the top picture you're passing transform info to the 'part_creep' node NOT geometry in the second picture you're creating geometry with the sphere1 node... if you want to bring in geometry use the object_merge node. oh so, rather than the other input node, object merge would work fine. I got it. Thanks, Quote Link to comment Share on other sites More sharing options...
