Fabiano Berlim Posted July 23, 2008 Share Posted July 23, 2008 Hi I have a basic head Geometry with Uv made inside Zbrush. I start a vex vop shader and assign a texture to it. In the Scene View i am getting the right result. But when I render something goes very wrong. The head just have a constant red/orange color. It's strange. If I put a mandril.pic, it works. So I tried to convert the image to all sorts of formats. Still nothing!!! I tried to use a basic surface... Still nothing. basicHead.zipFetching info... I am sending the .hip file, the texture file (jpg), the OGL Render and a Mantra Render. The shader is insider the Head Geo. If someone could help me I will aprecciate a lot!!! I am learning Houdini, so I don't have hurry. Sorry for the english and thanks in advance!!! Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted July 23, 2008 Author Share Posted July 23, 2008 ok!!! Fixed... or almost. I convert the image to .pic Does Houdini support any other kind of format? But now I have another problem!!! These white square. I have checked the UVs, and they look correctly. If someone could help me again!!! Thanks!!! Quote Link to comment Share on other sites More sharing options...
Symbolic Posted October 16, 2008 Share Posted October 16, 2008 Have you checked the geometry... sometimes you get overlapping faces or normals problems... shared faces etc... Quote Link to comment Share on other sites More sharing options...
LEO-oo- Posted October 17, 2008 Share Posted October 17, 2008 I recommend - unfold the geometry and then export for ZBrush. Please check the ODWiki for more information regarding H/ZB-pipeline. P.S. If you want - send me the obj-file - I will check it. Send me a PM. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted October 17, 2008 Share Posted October 17, 2008 Fabiano Berlim said: ok!!! Fixed... or almost.I convert the image to .pic Does Houdini support any other kind of format? Yes, check in the docs its supports all common formats. .pic and .rat are its own formats and .rat is recommended for all things texture related. Quote Link to comment Share on other sites More sharing options...
