zasid Posted July 30, 2008 Share Posted July 30, 2008 Hello guys, I need to setup Stone Wall Procedural shader mixed a custom displacement map so that I can get both effects over my rocky surface how can I setup this shader ?I will be thankful regards Zasid Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted July 30, 2008 Share Posted July 30, 2008 Hi there. you probably want to check out a variant of cellular noise for this stuff... may be even the likes of Voronoi might help too. You should be able to find how voronoi pattern works from the net I think. The basics of it is fairly simple. Quote Link to comment Share on other sites More sharing options...
zasid Posted July 30, 2008 Author Share Posted July 30, 2008 how do I mix the procedural patter with my custom map? Quote Link to comment Share on other sites More sharing options...
Jason Posted July 30, 2008 Share Posted July 30, 2008 how do I mix the procedural patter with my custom map? Can you extract a bump map from your texturemap? Check this also: http://crazybump.com/ Quote Link to comment Share on other sites More sharing options...
zasid Posted July 30, 2008 Author Share Posted July 30, 2008 Hi Jason I know about the app.I need to know how would be my VEX shader network setup to create such a shader. THanks Quote Link to comment Share on other sites More sharing options...
Jason Posted July 30, 2008 Share Posted July 30, 2008 Hi JasonI know about the app.I need to know how would be my VEX shader network setup to create such a shader. THanks Do you have a bump map for your colour map? Or are you looking to make a completely unrelated displacement? Quote Link to comment Share on other sites More sharing options...
zasid Posted July 30, 2008 Author Share Posted July 30, 2008 no I will be using bitmap generated by crazy bump and I want to mix it with something procedural lets say voronic noise. Quote Link to comment Share on other sites More sharing options...
Alanw Posted July 30, 2008 Share Posted July 30, 2008 Something like this should get you started. It's very simple, so you may need to tweak it. Quote Link to comment Share on other sites More sharing options...
zasid Posted July 31, 2008 Author Share Posted July 31, 2008 thanks Alan that's wat I wanted .I will give it a try thanks once again. Quote Link to comment Share on other sites More sharing options...
Alanw Posted July 31, 2008 Share Posted July 31, 2008 Sure thing, let me know if you need the HIP. Quote Link to comment Share on other sites More sharing options...
