Tiago Posted July 31, 2008 Share Posted July 31, 2008 Hello, I have to use a bevel after the uv unwrap, and it messes up the uv map, which I already knew. My problem is: I tried to UV edit the messed up points, but it's not possible to select just the ones I want, since others that are correctly placed in the uv map move as well... Anyone as an idea why this happens and what are the ways around it? Thank you very much in advance, Tiago Quote Link to comment Share on other sites More sharing options...
Alanw Posted July 31, 2008 Share Posted July 31, 2008 Is it possible to move polygons instead of points to achieve your goal? Moving Polys in the UV editor will allow you to ignore connectivity. (it seems) I sometimes run into this issue as well and it makes me think I'm approaching things wrong. I know in XSI you can turn "connectivity" on and off for all components, and it would be nice to have this functionality inside Houdini as well. On another note, www.houdinitools.com has some wonderful additions to the current UV toolset so you may want to check it out if you plan to do much UV mapping in Houdini. In particular the UV unwrap LSCM Sop, and UV uniform SOP are great. They were built for Houdini 8 on Windows, but I've compiled them on Linux for Houdini 9.5 without any problems so far. -Alan Quote Link to comment Share on other sites More sharing options...
old school Posted August 1, 2008 Share Posted August 1, 2008 You may be moving points instead of vertices. RMB (Right Mouse Button) on the Geometry Select mode button (upper left viewport second down) and choose vertex selections. Or just hit 5 in the view port. Quote Link to comment Share on other sites More sharing options...
Tiago Posted August 1, 2008 Author Share Posted August 1, 2008 Thank you guys, Polygons wouldn't do for me in that case, but vertices worked great. And I thought that I already pressed all those buttons... Too much time in front of the computer maybe Tiago Quote Link to comment Share on other sites More sharing options...
