KrisStaber Posted August 1, 2008 Share Posted August 1, 2008 hey since i only have 3 weeks of real houdini experience i am sure there is a quicker way to do some things i am interested in little things like the [ctrl + shift + lmb] on a channel to delete a key or expression for example or the supercool mmb drag ladder thingy for example: is there something to set channel values to defaults thats quicker than the right click drop down menue in rigging or animation you need that A LOT would be cool if there was a great way or how to get rid of that stupid behaviour when you type an expression and your mousecursor is one pixel below the line you are typing. then houdini brings up that yellow window telling you what you could type (which is great) but houdini stops accepting what you type - really annoying "feature" or that that little helper window actually cant be used to click on what it shows when you work om the editor (alt+e) Quote Link to comment Share on other sites More sharing options...
rdg Posted August 1, 2008 Share Posted August 1, 2008 is there something to set channel values to defaults thats quicker than the right click drop down menue ctrl - MMB or how to get rid of that stupid behaviour when you type an expression and your mousecursor is one pixel below the line you are typing. Preferences - Scripting - Context Sensitive Popup Help stops this partly, I guess. Hope this helps, Georg Quote Link to comment Share on other sites More sharing options...
old school Posted August 1, 2008 Share Posted August 1, 2008 Most of the shortcuts are on all the menus that you get when you RMB (RightMouseButton) on parameters, operators, etc. Most items have menus. Quote Link to comment Share on other sites More sharing options...
KrisStaber Posted August 2, 2008 Author Share Posted August 2, 2008 thanks a lot that crtl mmb is a great timesaver Quote Link to comment Share on other sites More sharing options...
