capturing geometry tutorials
KrisStaber
i am getting into houdni rigging and after a day of pain and suffering i think i slowly start to see the light when it comes to capturing geometry
but a lot is still not 100% clear and a bit weired
i am sure a good tutorial would help there
but i couldnt really find anything
questions:
there seem to be a lot of different capturing methods in houdini and they dont seem to update the color on the mesh same way
there is the capture regions one
the painting weights - that one often seem to lock itsself up
the moving the slider on the bones with points selected
and probably a couple of other ones
can i use them all at once ?
how do you usually envelope a high quality character to a bit mor advanced rig ?
why do the painting weights one often lock up
i then have the brush and all but i cant paint
thanks
isnt there a capturing method where i can grab the mesh and the bones, and then tell it to find X amount of closest bones for every single vertex ?
so that every vertex grabs say two bones that are closest to it, and therefore every vertex / meshpoint is captured ?
Proximity Capture is what you want, yes?
sort of
but i would like it from the other end
that proximity capture starts from every bone and just calculates a distance (sliders in the lower left) and captures the geometry according to that distance
i would like to have it start from every vertex / point and grab a predefined ammount of bones that are closest in distance to that vertex
this way every point in the mesh will be captured and you have some sort of usable result to work from.
with houdinis capture proximity its very problematic when you compare the spine (big distance to bone) to fingers (small distance)
i am sure there is a straight forward workflow in capturing geometry in houdini
i just havent found it yet :-/
I'm sure in the algorithm it must do it from the point's perspective, searching for the closest bones. The CaptureProximity does support a "Max Influences" (default of 2) parameter too, so I'm not sure what else you might need?
The CaptureRegion style I've find useful in the past, and really easy to use - and the Metaball Capture is excellent for getting better weighting for muscled characters - or even cartoony ones. And you can do this very interactively, at least with the CaptureRegion pills.
