Fomal Posted August 7, 2008 Share Posted August 7, 2008 (edited) Hi, Posted a question before, solved that part, but didn't get the results I need. My problem is that I've animated some points and i'm sorting the primitives later. The sorting is based on a proximity to point but since the geo is animated slightly, the primitive numbers will change from frame to frame. Is there any way to I can lock the primitive numbers after the proximity to point has calculated the new order? Any help is appreciated! Cheers Coen Edited August 7, 2008 by Fomal Quote Link to comment Share on other sites More sharing options...
edward Posted August 7, 2008 Share Posted August 7, 2008 Sort the primitives first? Quote Link to comment Share on other sites More sharing options...
