Henster Posted March 22, 2003 Share Posted March 22, 2003 Hi all, I've set up all the paths including the shader path in the output tab. I get the script in and can select and apply it. But when rendered it just comes out grey. I guess the codes right since I'm getting it from slim. Any ideas? Also, I've lost all the previous shaders default to houdini. I've put it a & into the envir path so it looks for the old one. I hope houdini 6 makes this a bit easier. Cheers The Henster Quote Link to comment Share on other sites More sharing options...
Xiangbuilder Posted June 11, 2003 Share Posted June 11, 2003 About Renderman's default shaders which had existed after I set up Renderman and not are the shaders are customized by me. I can only use ri_spatter1, ri_rmarble1, ri_stone1 and some light. Can't see the colors of other shaders. Quote Link to comment Share on other sites More sharing options...
