foreachSOP again
Hi all,
I'm not sure if that's possible, I am looking for a way to store modified geometry from the first loop and apply it to the next iteration. I understand foreach is designed for the inputs do not change over the time. Do you think the only workaround would be to save somehow each modified iteration to disc and reread the geometry in the next loop? Any ideas?
thanks
kuba
Hi all,
thanks
kuba
Sounds like you're interested in the sop solver within dops. You can alter geometry over time, and have it retain whatever alterations were done in the previous frame.
