kensonuken Posted August 15, 2008 Share Posted August 15, 2008 I use maya for mesh output so I want to dump the obj sequence on disk and then I would like to know how to read that obj sequence into Houdini and then convert this into IFB format to render?? but the trick is that I want all this in the command line.... cmd> loading an obj sequence into Houdini without opening Houdini cmd> converting the obj sequence into IFB sequence... pls help me... Quote Link to comment Share on other sites More sharing options...
edward Posted August 15, 2008 Share Posted August 15, 2008 If you're trying to do delayed archives, then you don't need an IFD sequence as I mentioned in the other thread. To convert an .obj file into a .bgeo, you can use the gconvert utility. Or use gwavefront utility directly. Quote Link to comment Share on other sites More sharing options...
