SHOP / Export
hey
it's for outputting image planes!
if you go to your mantra node>output tab, at the bottom is "Extra image planes". if you add one, another section will be exposed, in the VEX Variable you can type in your export name. eg. diffuseExport
this will output only that component of your shader.
hope that helps
jason
